Semantic Layer Exports Crossed Out
  • September 25, 2024
  • 35 views
kerry_bespoke
Good Day
We are experiencing an issue with a TX Project’s Semantic Layer Exports. For one user’s desktop install of TX they are getting the following red X’s over the exports. I have tried to re-download the Custom Components and installed the SQL and File Export items. Only the SQL Exports had the red X removed. The file exports still have them after installing the custom component. Any ideas why this is still not working?
Hi @kerry_bespoke are you working on a VM? does the affected user login with a different user account onto the VM? If so can you please ask the user to login with their user and install the File export component and then restart the VM?
kerry_bespoke
  • 23 replies
Hi @Christian Hauggaard , they are using a VM and logging in with a different user account.
I will meet with the user and try out your suggestion and let you know how we get on.
Kerry
