open a project will result in an "out of bounds index/array" error,
  • September 6, 2023
  • 115 views
After saving a version of timextender, probably we where two person who incidentally did it at the same time, we run into "out of bounds index/array".
Now we can’t open the latest version and when trying to deploy an earlier version we get the “out of bounds index/array” anyway.
The environment is all in azure so we have the repository database accessible.
Would it be possible to just restore the database to a point in time before we hade the incident.
I talked with a colleague and he recommended using this community for advise.
@anders.bengtsson
I guess, but normally you would add a ticket about the issue with your repository.
  • 1020 replies
  • September 6, 2023
@anders.bengtsson
But how do you do a normal backup from an azure database? Is that possible,
Hi @anders.bengtsson thanks for submitting a support ticket, let us keep the communication in there :)
