How to stop an execution in TimeXtender DG Desktop
Roy V
  • 56 replies
How can I stop a process from running in the TimeXtender DG Desktop application?
I see an article about a process queue but nor in the portal nor in the desktop application I can see this menu. Maybe that is a functionality in the old version?
Hi ​@Roy V ,
you can get to the other browser interface by adding /dg to the url. So <org>.exmon.com/dg could show the other interface.
devin.tiemens
  • 84 replies
  • February 27, 2025
Hi Roy,as far as i have seen now is that the Process Queue in the DG Portal is only available in the payed license. Are you using the license included with TX data Integrator?
@Roy V please select Process Management
And then select process queue
and then select the task(s) and click Stop Executions
Roy V
  • 56 replies
  • March 10, 2025
I don’t have this layout. If I am correct that are pictures of the old portal layout.
I have the portal that looks like this:
and the desktop version that looks like this:
So there is no exception manager.
So I assume Devin is right that this is not part of the license that comes with TX Data Integrator?
Can you confirm that or is the functionality of this process queue planned to be added to the new DG portal?
Would be strange if you can't stop jobs as part of the TX data integrator license but only start them.
  • 662 replies
  • March 10, 2025
Hi ​@Roy V ,
Roy V
  • 56 replies
  • March 10, 2025
Hi Rory
Thanksa lot. Now I can see a similar interface.
However it does not show me the menu under exception manager (and I an admin) so probably with only the TX data integrator license you don't have this option. Hope this will be added to Turnkey or the Desktop application.
  • Explorer
  • 9 replies
  • March 27, 2025
Hello,
Any updates on this? For example I have this execution that is stuck in the Exmon and the TX interface:
I have no way to kill this execution. We have to wait for it to hit the timeout setting. We could ofcourse set a better timeout setting but it would also be nice to have a button somewhere that allows us to cancel the job.
I tried redeploying the job / process map but that does not overwrite running jobs. I can’t start a new run because this one is running:
I don’t have the option to switch to Process Management in the old interface:
Hi ​@Mvest
Just to clarify - are you scheduling jobs or execution packages via TimeXtender Orchestration?
Do you see any error messages in the event viewer on the application VM?
  • Explorer
  • 9 replies
  • March 27, 2025
We use the Schedule Groups in Exmon to schedule a process, and a process contains ODX transfer tasks + execution packages. We have no more jobs with an active schedule in TimeXtender Data Integration itself.
There are no error messages in the Event Viewer, until it hits the timeout setting:
The timeouts happen very rarely. But when it does happen and if we notice it, it would be nice to end a task manually using the interface.
@Mvest I have created a support ticket for this
devin.tiemens
  • 84 replies
  • April 4, 2025
Still not having the option to stop an execution via the process queue:
Am I correct that this is only possible in the payed license? And if so, are there any plans to add this option to all licenses?
Kind regards,
Devin
Hi ​@devin.tiemens
can you please try accessing the URL manually? Please change the relevant parts of the below URL
https://timextender.exmon.com/dg/Ti/QP/ProcessQueue
devin.tiemens
  • 84 replies
  • April 4, 2025
Great this workaround works, good to know! But please add this button to all licenses.
devin.tiemens
  • 84 replies
  • April 4, 2025
