Installing 6221.1
I try to upgrade  version 6221.1 for  customer Dorel.eu . I have the license number. But it requires me to log onto one of your servers to get authorisation . I cannot do that with this user  (not a dorel user).
What should I do ?
Hi Alain
6221.1 does not require a license number. 6221.1 is the new cloud based version of TimeXtender. Please note that it is not possible at the moment to upgrade a project from 20.10 to the new version. We plan to release a migration tool to help migrate 20.10 projects to the new version. You can sign up for free to try 6221.1 in the new TimeXtender Portal
Hi Alain
  • Explorer
  • 5 replies
  • May 25, 2023
@Christian Hauggaard; any news on the migration tool?
My infrastructure dept. want’s to upgrade to/install SQL 2022 servers, and if I can’t migrate I’ll have to re-do my projects :-(.
Hi @Anders The migration tool is undergoing testing at the moment. The legacy version (20.10.41 and up) supports SQL Server 2022. Perhaps you can upgrade the legacy version in the meantime?
  • Explorer
  • 5 replies
  • May 31, 2023
Thank you @Christian Hauggaard, I was able to install 20.10.42, and set everything up. Moving from DEV server to this PROD server went smoothly as well.
Only issue is that I can’t execute any tables. No matter how I set the server version, I end up with an error: “Unknown destination server version”.
So, still locked.
