Power BI dataset as data source
  • November 28, 2023
  • 100 views
Has anyone used a Power BI dataset as a data source? I have tried using the CData SSAS connector but can not get it to work. Any advice would be appreciated.
Best,
//Pontus
Hi @pontus.berglund
Please try the Microsoft Power BI XMLA 2023 Provider with the below settings. Please note this requires premium license/workspaces. Documentation for the provider can be found here.
I’ve also tried a bit with the Any source OLE DB, but with no success.
Hi @pontus.berglund
Hi @Christian Hauggaard,
Thanks! I have no idea how I missed that one. The Any Source OLE DB did work in the end, but only with the use of custom query tables.
I will try the Power BI XMLA 2023 connector and let you know how it goes.
