TimeXtender REST Data Source (5.0) in combination with dynamic values
I'm using the TimeXtender REST Data Source (5.0) in combination with dynamic values.
The API endpoint needs a filter (Period) in order to work.
As you can see in the last screenshot the dynamic value query refers to a table in TX.
This table contains all the yearmonth combinations of 2023: 202301, 202302, 202303 etc.
When the datasource is executed in Timextender desktop it only returns the following months: 202301, 202302, 202306, 202312.
It seems like the filter does not recognize all the yearmonth combinations or skips most of the months.
Has anyone had the same issue or experience with this configuration?
In the screenshots you can see the curent pagination and parameter configuration.
I’m also using table flattening but that doesn’t seem to make a difference.
Thank you.
Kind regards,
Joris de Leeuw
Hi @Christian Hauggaard & @jorisdl
I have tested it in the newest release. There is an issue with pagination, which the developers have found.
It is fixed in the 6.3.0.0 release
  • June 24, 2024
Hi @jorisdl
Have you tried this in version 6.1
Hi @jorisdl
As Thomas mentions above, have you tried this in the latest version of the TimeXtender REST Data Source (now 6.2)?
