Execution packages not running concurrently
  • December 3, 2024
  • 50 views
Hi all,
We are unable to run two execution packages concurrently on the same instance. They are scheduled using Jobs. The packages have no common tables involved. We have made sure to check the other package under “Concurrent packages” under Edit Execution Package (and deploying after).
Is running packages concurrently supposed to work when scheduled using Jobs?
Will it be supported with Orchestration?
Thanks for any input!
Version: 6766.1
Best answer by rvgfox
In TX or using Exmon, the jobs do not run concurrently. In Exmon you can configure your execution packages to run concurrently.
  • December 3, 2024
  • December 3, 2024
concurrent running of Prepare tasks requires the latest release of Orchestration and TDI.
@sigsol please see the following for more information:
https://support.timextender.com/executions-jobs-110/enhanced-integration-between-timextender-data-integration-and-orchestration-2634?tid=2634&fid=110
Please let us know if you have any follow up questions
