Property cannot be updated or deleted. Property 'OwnerId' does not exist for 'object specified'.
  • November 9, 2021
  • 26 views
sierd.zuiderveld
Hi, I tried to execute a transfer task on my data source however I encountered the following error:
 The execution failed with error:
System.Data.SqlClient.SqlException (0x80131904): Property cannot be updated or deleted. Property 'OwnerId' does not exist for 'object specified'.
at System.Data.SqlClient.SqlConnection.OnError(SqlException exception, Boolean breakConnection, Action`1 wrapCloseInAction)
at System.Data.SqlClient.TdsParser.ThrowExceptionAndWarning(TdsParserStateObject stateObj, Boolean callerHasConnectionLock, Boolean asyncClose)
at System.Data.SqlClient.TdsParser.TryRun(RunBehavior runBehavior, SqlCommand cmdHandler, SqlDataReader dataStream, BulkCopySimpleResultSet bulkCopyHandler, TdsParserStateObject stateObj, Boolean& dataReady)
at System.Data.SqlClient.SqlCommand.RunExecuteNonQueryTds(String methodName, Boolean async, Int32 timeout, Boolean asyncWrite)
at System.Data.SqlClient.SqlCommand.InternalExecuteNonQuery(TaskCompletionSource`1 completion, String methodName, Boolean sendToPipe, Int32 timeout, Boolean& usedCache, Boolean asyncWrite, Boolean inRetry)
at System.Data.SqlClient.SqlCommand.ExecuteNonQuery()
at DataStorageEngine.SQL.SQLStorageEngine.ValidateStorage(SqlCommand command, Boolean tryTakeOwnership, Boolean throwIfInvalid)
at DataStorageEngine.SQL.SQLStorageEngine.TransferData(IDataSourceEngine dataSourceEngine, ExecutionTaskModel taskModel, List`1 metaStructures, Boolean forceFullLoad, SecurityExecutionModel securityExecutionModel)
at ExecutionEngine.Action.StandardAction.Execute()
at ExecutionEngine.Action.ExecutionAction.<.ctor>b__9_0()
ClientConnectionId:526a0d89-6943-4fe1-bcc4-29429c0cd667
Error Number:15217,State:2,Class:16
ClientConnectionId before routing:d564a8d7-5b0a-4e14-98f0-cc41ffb7670d
Routing Destination:dd507851011a.HS3.tr8521.westeurope1-a.worker.database.windows.net,11013
This happened after I successfully deployed and executed some new Tables with relations. I don't know how to fix this issue, any help would be appreciated!
Best answer by Syed Yousuf
Hi Sierd,
Since you have already contacted Technical Support for this, our team will research and follow-up on the support ticket.
Best regards,
Syed Yousuf
  • 82 replies
  • November 9, 2021
Hi Sierd,
Best regards,
Syed Yousuf
