executing a package from the command line of TX Remote Control
Is it possible to execute a package from the command line of TX Remote Control?
Best answer by JTreadwell
Hi Thai, absolutely! See here: https://legacysupport.timextender.com/hc/en-us/articles/210439143-How-to-Start-an-Execution-Package-from-the-Command-Line
Please feel free to use the search our knowledge base which is full of useful articles like this. Thanks!
JTreadwell
  • March 11, 2020
Hi Joseph, Thanks for your reply. Just to be sure..
The mentioned article is apply to timeXtender 4.5, tX2012, TX2014, TX DWA, Discovery Hub. Can it also be use with TX Remote Control application? If yes the command line should be:
TXRemoteControl.exe <ProjectName> <Execution Package Name> ??
Thanks in advance.
  • March 11, 2020
and I get warning when i tried to download the TX Remote Controle appl.
  • March 11, 2020
Hi Thai
Go to this folder in your current DH installation.
C:\Program Files\Discovery Hub\Discovery Hub 20.1.5.64
In here you will find the newest version of the remote control program.
  • March 11, 2020
Also
You can't execute the TxRemoteControl.exe from the command line.
You can execute packages with the remote control like this.
And you can execute a package in a project like so.
Those are the options.
