Connect to MongoDB
  • November 18, 2021
  • 97 views
I'm trying to connect to MongoDB and load data  into Timextender
I have a ODBC driver setup, and test connection works.
In Timextender I have ODBC Generic Data setup, and test connection works and to Synchronize Data Source works as well.
But when I try to execute the data transfer from MongoDB into Timextender then I get an error.
As discussed in the support ticket, the following error messages were present:
' error: unexpected SUB at position 245
' error: unexpected STRING at position 342 near gr_notifications
A bug fix (12567) was released in 20.10.26 to handle the issue of Incorrect Accent grave sign in General ODBC setup. The Accent Grave type was character ' this has been changed to `. ODBC connections using the Accent Grave are update to use the new Single Quote.
  • 82 replies
  • November 18, 2021
As a workaround, you may test it with CData MongoDB provider.
Creating a support ticket to follow-up on error details.
peter.jensen
  • 42 replies
  • March 18, 2025
Using TX Classic (V20.10.61) - what’s the preferred way to connect to a MongoDB ?
I have an ODBC setup, and when I sync the objects, we get a list of tables and flattened tables (which are JSON’s in the MongoDB collection).
However, when previewing such tables I often get an error - saying that some columns don’t exist.  Is there a specific ODBC driver we should use, or specific options we should set in the connection to make this work?
