Persistent mapping error message on syncing MDW with ODX
  • September 26, 2024
  • 4 replies
  • 79 views
  • 7 replies
Dear all,
When synchronizing the mdw with the odx through right mouse click on the odx and selecting “Synchronize (...)”, the error messages as attached always show up. “Synchronize with Remapping (...)” only leads to complete removal of the field mappings in the subject tables.
As there are other ways to sync the mdw with the odx, it’s still possible to work with the subject tables in the mdw. Nevertheless i wonder what causes the error messages and would like to eliminate them along with the risk of having to redo all work on the tables in a later stage.
Best answer by Fench
Hi @Thomas Lind
Upon your diagnosis we updated to version 6766.1, which fully solved the issue.
Thank you! Hope to encounter you here next time.
Best regards
  • 1037 replies
Hi @Fench
What version are you on?
  • 7 replies
Hi Thomas,
Version 6718.1
Next time i’ll mention that in my question.
  • 1037 replies
Hi @Fench
I checked the Product updates for releases newer than this. I found this fix in version 6744.1.
  • Synchronizing the Prepare instance (MDW) with an Ingest instance (ODX) would show tables as missing when the data source had "data on demand" enabled and no execution tasks were added on the data source
Does that fit as an description of the tables it happens on when you use that option?
  • 7 replies
  • September 27, 2024
Hi @Thomas Lind
Best regards
