Release Notes
TimeXtender Portal r. 2023-06-05
Related products:TimeXtender Portal
Thomas Hjermitslev
Today, we’ve published a minor release of TimeXtender Portal with the following changes:
New
  • Custom firewall rules for instances: You can now grant specific IP addresses access to an instance. Access to your TimeXtender instances are protected by dynamically created firewall rules, but in rare cases, the automatic system will not create the correct rules to allow access from TimeXtender Desktop. With the new feature, you can add additional rules if the automated system, for some reason, does not work for you.
Changed
  • When you add and edit data sources, you’ll now find a handy menu on the left to help you navigate the forms, which can be rather long for some data source providers.
Fixed
This list includes all fixes released since TimeXtender 6221.1, including hotfixes.
  • Adding missing activity logging for data sources
  • When moving a user, the user would get all possible user-level permissions at the destination company.
  • "Create instance" would sometimes fail if a company had previously deleted instances
  • "Move company" could not find any valid destinations.
  • When merging two companies, an outdated warning about ODX client secrets would be displayed.
  • Editing your company on the ‘My company’ page would fail
  • Some  error messages from the backend would be replaced with generic messages when displayed in the UI.
  • Checking status on a running job in TimeXtender Desktop would fail
  • Fixed an issue where loading the list of data sources could fail
  • Fixed intermittent threading error on public endpoints
  • Updated .NET framework
