Documentation for TimeXtender REST connector options/variables
  • April 19, 2024
  • 5 replies
  • 132 views
In many of the tutorials for dealing with specific types of APIs reference is made to internal variables like {TX_CurrentPage} and others that can be leveraged to implement things like pagination. As far as I can find there does not seem to be a list of such items and what they do. Could this be made available?
@rory.smith
I added the part about builtin options Friday afternoon. There is not supposed to be more than these, but if new ones is added, I will make sure to add it to the guide and what their purpose is.
Hi @rory.smith
The variables {TX_NextPage} and {TX_CurrentPage} are covered here under Pagination section
Please confirm if these are the variables you are referring to
  • 662 replies
  • April 22, 2024
Hi @Christian Hauggaard ,
thanks - I think it would be more clear to have a separate section listing the variables and their specific meaning. While I can apply this tutorial, I would prefer to know exactly what these variables (and any future new ones) mean.
@rory.smith thanks for the feedback we will take this into account going forward
  • 1036 replies
  • April 22, 2024
@rory.smith
andrew.gebhard
Hi @Thomas Lind, would it be possible to document the data-type names and conversions for the REST data source?
For example, I am trying to override datatypes on a data source in ODX to make all string type fields nvarchar(max). Using datatype contains(ignore case) = ‘string’ does not work.
Would be great to know what the datatypes are called, and what they translate to in data-lake and SQL.
I realize that override datatypes only takes effect if you delete the data files from the storage blob. string to varchar(max) works as expected.
Kind regards,
Andrew
