Download TimeXtender Master Data Management
Dagný Björk Stefánsdóttir
Here are a few different methods to install new versions of TimeXtender Master Data Management onto your computer.
Current version: 25.1.0
Direct download links:
25.1.0
24.3.0
24.2.0
Download from the web
If your organization has enabled TimeXtender MDM Web client, you can download the Windows client from the web.
  1. Login to the web client by visiting: https://login.exmon.com/
  2. Click on your user name in the top right corner and click "Download Desktop Version"
Invitation email
When someone invites you to TimeXtender MDM, you will receive an email with a download link to the TimeXtender MDM client.
A TimeXtender MDM administrator can resend you an invite when needed.
  1. Click the Settings button
  2. Select "User Configuration", select the appropriate user and click "Resend invitation email"
Copy download link
If you have access to TimeXtender MDM on another computer you can copy a link to the installer within TimeXtender MDM
  1. Click Settings
  2. Select About and click "Download TimeXtender MDM" and "Copy setup file to Clipboard"
Now you have the path to the setup file on your clipboard and can either send a link to your colleague or open the link in your preferred browser to download.
Note: If you downloaded an incorrect version, TimeXtender will help you downgrade to the correct version.
