Error: No suitable Oracle driver installed
Symptoms
Reading objects from an Oracle data source results in an error message, but Test Connection to the Oracle data source works
'No suitable Oracle driver installed'
Cause
The Oracle Data Provider may be a different bit version than TimeXtender
Resolution
Ensure that Oracle Data Provider is the correct bit version
