Clone Instances
  • September 6, 2024
  • 243 views
This articles describes how to clone instances, which saves time, for example when creating instances for separate environments. Cloning an instance creates a copy of an instance with the same configuration.
Clone an Instance
  1. Go to the TimeXtender Portal and select the instance you wish to clone
  2. Select Clone
  3. Rename the cloned instance and change any settings as required, or keep the configuration as-is, and click Save
