Extract Data from SharePoint Lists
  • February 13, 2025
  • 6 replies
  • 262 views
Prerequisites
Create an Azure App Registration
The App Registration should use the Microsoft Graph API with the following permissions:
Finding the List ID
Use Postman to find the Site ID. Use the Site ID to find the List ID. You can find these by using Postman and by looking at the Graph API collection Graph Fork. You can use the app to connect to this and locate the SharePoint folder under Application. In there you have two requests, https://graph.microsoft.com/v1.0/sites and https://graph.microsoft.com/v1.0/sites/{{SiteID}}/lists. Use sites to find the site ID and use the SiteID to find the List ID. You can also find the ListID by navigating to the SharePoint  list and then clicking List settings and then copying the ListID from the URL
Use the TimeXtender REST data source connection
Connection Settings
Use the following Base URL (where {{SiteID}} is the Site ID found in Postman):
Endpoints
Create the endpoint using the following path (where {{ListID}} is the List ID found in Postman). If you have more than one SharePoint List, then create an Endpoint for each one.
/{{ListID}}/items?expand=fields
Use the TimeXtender OData source connection
Connection Settings
Endpoints
Create the endpoint using the following path (where {{ListID}} is the List ID found in Postman). If you have more than one SharePoint List then create an Endpoint for each one.
  • April 30, 2025
Hi ​@Christian Hauggaard
Thank you for this manual. Unfortunately this just doesn't seem to work.
It gives me several 401 errors like: “Response status code does not indicate success: 401 (). System.Net.Http.HttpRequestException: Response status code does not indicate success: 401 (). at”
We've tried several authentication steps, but all without succes.
Any thoughts on how to fix this error?
@r.miltenburg please submit a support ticket by emailing support@timextender.com. Please include description and screenshots of your settings and current configuration
  • July 10, 2025
I see now several lookupId fields in the data with corresponding column names like the columns of the sharepoint list. But how can I get the values these ID's correspond to?
  • July 14, 2025
Hi ​@Mies
I made my own setup.
The result came like so.
I could not control the names of the fields, only the order. So my fields used for table flattening was just that.
I then gave the fields proper names similar to what I have in my list once it came into a table.
I could also name it here, but the issue is that the Graph API doesn’t return proper names.
  • September 30, 2025
We're currently running into the problem that we're only receiving an Author_ID for the person/ group fields in Sharepoint list. Unfortunately, the table flattening does't show a table or field where we can link the Author_ID to the correct person. How do you solve this, or how can it be resolved?
Hi ​@r.miltenburg can you please create a support ticket by sending an email to support@timextender.com ? thanks
