Overview of Data Sources and Provider Types
  • May 17, 2023
  • 620 views
This article describes the different provider types for data sources in TimeXtender Data Integration (TDI). Often there are multiple ways to connect to a data source, and several provider types to choose from. This article aims to provide an overview of the different options available to help inform decision-making around provider selection.
Provider Types
An Ingest instance can connect to a data source through one of five different types of providers:
  • TimeXtender enhanced: TDI's own providers with tweaks and improvements that usually makes this the best choice.
  • Local ADO.NET: Providers installed on the machine that are built on ADO.NET
  • Local OLE DB: Providers installed on the machine that supports the OLE DB standard
  • ADF: Providers from TimeXtender that use Azure Data Factory for transferring data.
  • Managed ADO.NET: Providers from CData, a third-party supplier of drivers and providers for connecting to a massive amount of different systems. For help with setting up CData providers, please refer to CData online documentation for ADO.NET providers at https://www.cdata.com/kb/help/
    Warning: CData data source providers are no longer supported or distributed by TimeXtender. We strongly recommend that you upgrade to ‘TimeXtender Enhanced’ providers.
