Deliver Instance Variable error
devin.tiemens
I am trying yo apply the new integrated Deliver Instance variable, but get an error when deploying the instance. When deleting the variable again, de depoyment and execution succeeds. I already tried the following:
  1. Synchronizing de Deliver instance
  2. Refreshing the environment
  3. Reopening TX
  4. Deleting and recreating the variable with a different name
  5. Trying the Fixed variable instance (which gives me the same issue)
Any suggestions?
Kinds regards,
Devin
@devin.tiemens I have reproduced the issue you describe, and have created a support ticket for this
  • March 7, 2025
judging from the stacktrace it looks like your repo might not be properly updated or corrupted. I guess that means a support ticket.
devin.tiemens
Hi Rory, thanks for the reply, I was also thinking about that, but in that case I would not expect to be able to deploy and execute when I delete the variable. Were you already able to use the deliver instance variable yet?
  • March 7, 2025
Yes #worksforme.
