This is what we get in the mail notification:
Finished executing project 'TXDictionary' Execution Package 'TXDictionary Full Project'
Execution failed
Start Time : 2021-04-26 16:46:23 End Time : 2021-04-26 16:46:35 on server: SRV12080 -Execute Execution Package TXDictionary Full Project 'Processing failed'
                             The current operation was cancelled because another operation in the transaction failed.
                             Details:
                             System.Exception
Execute Project:Info:DoStep() has not been called!
  -Execute Project
Execute Business Units:Info:Initialized
Execute Data Warehouses:Info:Initialized Execute SSAS Multidimensional Servers:Info:DoStep() has not been called!
Execute Semantic Models:Info:Initialized
    -Execute Semantic Models
Execute TXDictionary(Tabular or Qlik):Info:Initialized
      -Execute TXDictionary(Tabular or Qlik) Execute Tabular endpoint Tabular:Error:Processing failed
        -Execute Tabular endpoint Tabular 'Processing failed'
                            Details:
                            System.Exception
No child steps
            Hi Martin,
To get additional details on this error:
1. Check software prerequisites ( SQL Server Management Objects (SMO), Analysis Management Objects (AMO) etc. ) on the new server, as described in this article:
https://legacysupport.timextender.com/hc/en-us/articles/213530403-TimeXtender-Prerequisites#Application
2. Try to process the Tabular model in SSMS - it may show additional error details.
            Thanks! Processed the cube from SSMS and got a better error message:
Failed to save modifications to the server. Error returned: 'The size of a data value in table 'PackageExecutionTime' column 'ExecutionMessage' was too large to fit in that column.
That is easily fixed.
