I am currently testing RLS using a powerbi premium endpoint with the TX 6675.2 version.
Normally we use dynamic RLS, but since this did not work, for now i tried a manual setup:
I have added my user to a created Role
Then i have set the security setup and the endpoint to the Role i created.
The outcome in PowerBi Desktop when i connect to the PowerBI premium endpoint in the onelake datahun is that i don't see anything. No data at all. I would have expected that i would see the data for Bejo Andes Ltda.
Is this the correct setup for RLS in a PowerBI endpoint or am i missing something?
Hi @RobertU
The rights are saved on the DW instance data area that is connected to the SSL instance. We found that it was empty even after executions. So this was a bug. We have a release with a fix I can send to you.
The guy who found it @KaiMueller also worked out a workaround.
we found a workaround: We deploy the SSL which creates the security table. We then create a view with the same name as the security table (and delete the security table). We can then deploy & execute the SSL as normal and TX uses the view (this seems a litle bit like a pssible security problem to me :)). This works for now, but is hard to maintain for a lot of security rules.
