Lineage Visual diagram
Lineage and Visualization
  • February 6, 2023
  • 5 replies
  • 884 views
As your setup grows, the increasing complexity can make it hard to keep track of all objects and their dependencies. To help you with this, TimeXtender Data Integration (TDI) offers these visualization features: Data lineage and Relation Diagram. The relation diagram is only available on tables, while Data lineage is available for fields and measures in both Prepare and Deliver instances.
The purpose of data lineage is to show you where the object in question gets its data from. The relation diagram shows you the relations to and from the table in question.
Note:  It is recommended to save all changes in the instance before generating data lineage.
Showing Data Lineage or Relation Diagrams
To show data lineage, right click on a field, click Data Lineage:
  • Under Content section (on top-left) check boxes for objects to show, then click the refresh button to show the lineage.
Customizing the Display
In the visualization window, you have different options to customize the display:
  • Click an object to have the connections to and from the object highlighted.
  • Click and hold on an object to move it around and release the mouse button to place it.
  • Click the arrow in the header of an object to hide or show object details.
  • Right-click the background in the window to bring up a menu with different options for organizing and displaying the data:
    • Click Reset Layout to make TDI reset the layout.
    • Click Collapse All or Expand All to either collapse the objects to create a better overview, or expand the objects to see more details.
    • Click Zoom InZoom Out or Zoom 100% change the size of objects.
  • 231 replies
  • February 16, 2023
Is this feature related to “Object Dependencies” menu option:
For what this option is used?
  • 82 replies
  • February 16, 2023
You may configure dependencies on the table (right-click table > Advanced > Object Dependencies). Select the tables that should be executed prior to the selected table. This may help avoid a deadlock
  • March 21, 2023
Hi
Do the tables in question need to be deployed afterwards?
  • March 21, 2023
And another thing:
Are dependencies respected in multi-threaded execution packages?
It seems that the data lineage view show incorrect schema for the tables. It says that the scehma is [dbo] for all tables, even if they have different schemas. This is even the case in the screenshots in this post.
It would also be nice if you would bring back the feature to double click on a node to go to that object in the GUI. This is incredibly valuable when working in large solutions.
