Send parameters to Query and Compare Query
  • April 8, 2024
  • January 2, 2025 at 2:48 PM
  • 229 views
In this article, you will learn how to send parameters to Query and Compare Query, in TimeXtender Data Quality. If you need to, for example, filter results by some external value you can use Query Parameters.
Designing Queries with parameters
When designing your query parameters, you need to follow this format: {@parametername[default value]}
  • @parametername represents the name of the parameter you want to query.
  • [default value] is only used when testing the query in TimeXtender Data Quality.
  • You can add multiple parameters or reuse the same parameter.
In the example below, we select products by colour and price range. Specifically, we are using a test query in TimeXtender Data Quality to select black products that cost between 0 and 200.
If you are using query parameters with tests that use exception management, it is important to deselect “Automatically close exceptions when they are not found in query results”. You can do this by going into Advanced in Exception Management Properties.
Running Queries with parameters on the Portal
When executing the test from the portal, the user will be asked to fill in query parameters.
Running Queries with parameters with epcmd.exe
Queries that define parameters must be executed with parameters in the command line.
For example, to execute the query above:
epcmd --query 1 --@color "Black" --@pricefrom 0 --@priceto 200
Adding to Object Groups
You can add the same query multiple times into the object group to run with different parameters.
Parameter List
Parameter lists are a great way to limit what parameter values are available to the end users. There are two types of parameter lists, static lists and dynamic lists.
Static List
A static list has a set number of parameter values available and it requires a developer to change available values.
Static list format:
{@parametername[default: value][preview:value2][datatype:list][list_items: value1
|’Display Value1’, value2|’Display Value2’, value3|’Display Value3’]}
List_items contain a combination of key|display pairs, separated by commas. The key is the value that will be used by executions in TimeXtender Data Quality but the display value will be shown in TimeXtender Data Quality Portal.
Dynamic List
A dynamic list requires a reference to a T-SQL function that receives two integer parameters, @UserId and @SystemId and returns available parameter values.
Dynamic list format:
{@parametername[default: value][preview:value2][datatype:list][list_function:
client.get_all_users][list_function_key:user_id][list_function_display:user_name]}
List_function is the T-SQL function reference, list_function_key is the column name of the key used by executions in TimeXtender Data Quality and list_function_display is the value of the display shown in TimeXtender Data Quality Portal.
An example of a function that TimeXtender Data Quality could use:
CREATE FUNCTION [client].[get_all_users]
@UserId int, @SystemId int
RETURNS TABLE AS RETURN
SELECT user_id, user_name, full_name, email
FROM c_user
