Web - Integration with Microsoft Teams
  • April 8, 2024
  • June 16, 2025 at 11:10 AM
  • 166 views
We have optimized the Data Enrichment web experience so that you can easily integrate your data within Teams and have relevant data at your fingertips.
Step 1
Browse to the specific view in Data Enrichment you want to add to Microsoft Teams and copy the URL.
Step 2
In Microsoft Teams, open the desired Channel (1) and click + to add a new tab (2). Then select Website (3-4)
Step 3
Paste the URL you copied in step 1
Step 4
That's it! Now your data is integrated with your workflow.
The first time you open the tab you will be asked to log in (which is seamless with our Azure AD integration)
