Error message while configuring Environment
rbrandsma
Hi!
I have just installed TX 20.10.66.64 on a new server for a customer and following the steps of the “Configure Multiple Environments” article.
Created a service account and setup the Windows Services through TimeXtender. Logged in on TimeXtender with the Service account for prod and linked it to the prod repository (which is on a different server).
Now I'm trying to setup the production environment in TimeXtender. I opened Environment properties and clicked New Environment, gave it a name and filled in the address of the server (and instance) containing the prod repository. Filled in the ports.
When clicking OK to close the Add Environment window I almost immediately get the error from the printscreen below:
Has anyone come across this before?
that parameter indicates the machine the server service is on (and the ports), not the SQL Server instance holding the repository database. "Server: Type the server name or IP address of the production server.” - see: https://legacysupport.timextender.com/hc/en-us/articles/360051848351-Multiple-Environments
  • 731 replies
  • May 23, 2025
what are you filling in in the server field? It should be a dns name or ip, not a UNC path or whatever you have there with a \
rbrandsma
  • 15 replies
  • May 23, 2025
I'm filling in the server address\instance since the repository is on a different server that has several SQL server instances configured
  • 731 replies
  • May 23, 2025
rbrandsma
  • 15 replies
  • May 23, 2025
Thanks ​@rory.smith this seems to have resolved the message that I got!
