ExecutionEngine_x64 and JetDatamanager takes alot of resources
  • February 3, 2025
  • 8 replies
  • 69 views
hi there
After the latest update executionengine_x64 and Jet datamanager server takes 100% of my cpu ..
are there anyone who have experienced the same ?
Hi ​@truttafisker I have created a support ticket for this
  • 1092 replies
  • February 4, 2025
Hi ​@truttafisker
What version, is it 20.10.57?
The ExecutionEngine_x64.exe is the ODX when it is doing transfers. Do you run a lot of tasks when you see this?
  • 15 replies
  • February 4, 2025
hi ​@Thomas Lind
actually not .. I just started the software .. and have a connection to a few excel sheets and a BC (Business Central) connection .. that’s it ..
  • 1092 replies
  • February 4, 2025
Hi ​@truttafisker
Are you using the ODX for the BC and excel sheet data sources or is it a normal business unit?
  • 15 replies
  • February 4, 2025
Thomas Lind wrote:
Hi ​@truttafisker
correct ..
  • 1092 replies
  • February 10, 2025
Hi ​@truttafisker
Does it still run 100% or did you stop it?
Can you see if you can run small things like a single table or task to see if it then again returns to that level.
  • 15 replies
  • February 11, 2025
Thomas Lind wrote:
Hi ​@truttafisker
once in a while it runs 100% .. still .. but can’t figure out “when” or why it happens ..
  • 15 replies
  • February 26, 2025
awesome .. I will look into it asap
