Extracting credit usage from portal through api
  • June 27, 2023
  • 45 views
hi,
I’d like to have the option to extract the credit usage from our portal per month through an API or another endpoint. Are there any possibilities?
This will help me monitor the environment and usage across multiple developers.
Hi @VictorVink
Currently the API only shows info about jobs. This may change in the future.
  • 1160 replies
  • June 27, 2023
Hi @VictorVink
