Disable or Enable a User in Data Enrichment
If you need to enable or disable a user in Data Enrichment, you can do so through the administration controls.
Enable/ disable user
  1. Go to Settings and click User Configuration
  2. Select a User
  3. Click on Edit User
  4. Within the Edit User Details dialog, toggle the User Enabled checkmark to Disable or Enable a User for Login
