Permissions not updating immediately while Setting User Permissions in TimeXtender Orchestration
  • February 18, 2025
  • 29 views
Dagný Björk Stefánsdóttir
Symptoms
Users are unable to see the updated permissions immediately after changes are made.
Error: Permissions not updating immediately.
Cause
The issue may be related to user cache not being cleared immediately after permission changes.
Resolution
To resolve the issue, follow these steps:
  1. Ensure that the browsers cache is cleared after making changes to permissions.
  2. Test the permissions by giving access to specific execution packages to verify if the changes are applied correctly.
  3. Try using the "log in as" and "log out" features to troubleshoot user access issues.
