Running a TDI execution in Turnkey
This article describes how to run a TimeXtender Data Integration (TDI) execution in Turnkey and how to view execution logs.
  1. Navigate to a workspace that contains your process map
  2. Navigate to Process Maps tab
  3. Select your process map
  4. Select Run Process
  5. Select Start
Execution History
To view all execution log details:
  1. Navigate to your process map
  2. Select a package on the map
  3. On the right side, you will get a panel that contains recent executions
  4. You can click the log icon to see details for that particular execution
