Step-by-Step Guide to Download Executables for MDM and O&DQ
  • October 14, 2024
  • 728 views
Dagný Björk Stefánsdóttir
If you ever find yourself wishing you had access to all (older) versions of TimeXtender O&DQ and MDM apps here is your solution! Let's find out how to quickly download the executable versions of our solutions.
Links below will guide you to public-facing SharePoint folders that will enable you to download and run multiple versions of O&DQ and MDM clients. These are not installable files, just follow instructions below to run each version.
TimeXtender O&DQ: TimeXtender O&DQ
TimeXtender MDM: TimeXtender MDM
TimeXtender O&DQ
Open the link and select the version you are interested in.
Next step will be to press "Download" and wait patiently as the zipped folder is downloaded.
Extract the files from the folder and select "ExpectusAdmin.exe" to start the application
TimeXtender MDM
Extract the files from the folder and select "exMon.exe" to start the application.
