TimeXtender Orchestration API
  • May 13, 2026
  • 166 views
The Public Orchestration API lets external systems, CI/CD pipelines, and third-party tools read orchestration status, trigger executions, and retrieve logs — using the same access controls as the web application.
This API was introduced in TimeXtender Data Platform 26.2
Contents
  1. Base URL
  2. Getting started — creating an API key
  3. Authentication
  4. Common parameters
  5. Task types reference
  6. Endpoints
  7. Error reference
  8. Quick-start examples
Base URL
https://{tenant}.odq.timextender.com
Replace {tenant} with your customer subdomain (e.g. acme → https://acme.odq.timextender.com).
All endpoint paths in this document are relative to the base URL. A full request URL looks like:
https://acme.odq.timextender.com/api/v0/orchestration/workspaces
Note that the endpoint will change later this year to https://acme.timextender.com/api/...
API keys are managed inside the TDP web application. A key inherits the exact same permissions as the user who created it — workspace access, process map visibility, and everything else. Think of a key as a password for your account that can be used by a script or external system.
Creating a key
  1. Sign in to the TDP web application.
  2. Click your name or avatar in the bottom-left corner of the navigation and select User Preferences, or navigate directly to /all/preferences.
  3. Select the API Keys tab.
  4. Click Create.
  5. Enter a description that identifies what this key will be used for (e.g. Azure DevOps pipeline, Grafana dashboard). Maximum 100 characters.
  6. Click Create in the dialog.
  7. The full API key is displayed once. Copy it immediately — it cannot be retrieved again.
Security note: Treat your API key like a password. Store it in a secrets manager, environment variable, or CI/CD secret — never in source code or configuration files committed to version control.
The key has the format txk_ followed by 32 alphanumeric characters:
txk_ABCDEFGHIJKLMNOPQRSTUWXYZ1234567890
After creation, only a masked preview is shown in the UI (e.g. txk_••••••••j2frD).
Limits: Each user can have a maximum of 3 active keys at the same time. The Create button is disabled when you reach the limit.
Deleting a key
To delete one of your own keys:
  1. Go to Preferences → API Keys.
  2. Select the key in the list.
  3. Click Delete and confirm.
Deletion is immediate and permanent. Any request using the deleted key will receive 401 Unauthorized.
Admin: viewing and deleting all keys
Administrators can see every active key in the workspace and delete any of them:
  1. Go to Settings → API Keys.
  2. The grid shows all active keys with the owner's name and email, description, creation date, and last-used date.
  3. Select a key and click Delete to invalidate it immediately.
This is useful for offboarding users or responding to a suspected key compromise.
Authentication
Pass your API key in every request using the X-API-Key header:
GET /api/v0/orchestration/workspaces HTTP/1.1
Host: acme.odq.timextender.com
X-API-Key: txk_ABCDEFGHIJKLMNOPQRSTUWXYZ1234567890
The API key is validated on every request. The last_used timestamp on the key is updated automatically.
Authorization
A key carries the same permissions as the user who created it:
  • Only workspaces the user has access to are returned.
  • Process maps and tasks the user cannot see are excluded.
  • Trigger endpoints require Contributor access on the workspace; read endpoints require Viewer access.
Authentication errors
Status
Cause
401 Unauthorized
X-API-Key header missing or key not recognised
401 Unauthorized
The user account associated with the key has been deactivated
403 Forbidden
Key is valid but the user does not have sufficient access to the requested workspace
Common parameters
uat — Environment
Most endpoints accept a uat query parameter to target a specific data environment within the workspace.
Value
Meaning
Production or PROD
Production environment (default)
Development or DEV
Development environment
Test or TEST
Test environment
If omitted, Production is used. Passing an unrecognised value returns 400 Bad Request.
GET /api/v0/orchestration/finance/tasks?uat=Development
Pagination — limit and offset
All list endpoints support offset-based pagination.
Parameter
Default
Minimum
Description
limit
100 (execution history: 50)
1
Maximum items to return per page
offset
0
0
Number of items to skip
limit must be greater than 0 and offset must be 0 or greater — otherwise the request returns 400 Bad Request.
When the number of items returned is less than limit, you are on the last page.
# Page 1
GET /api/v0/orchestration/finance/tasks?limit=50&offset=0
# Page 2
GET /api/v0/orchestration/finance/tasks?limit=50&offset=50
# Page 3
GET /api/v0/orchestration/finance/tasks?limit=50&offset=100
The API uses stable PascalCase names for task types. Always use the taskType value returned by a list endpoint when constructing trigger or detail requests.
API name
Description
Query
Data quality query
CompareQuery
Compare query — validates data between two datasets
Rule
Data quality rule
Package
Execution package
ObjectGroup
Object group
Process
Process
ScheduleGroup
Schedule group
TestGroup
Test group
OrchestrationMap
Orchestration map (process map overview)
Link
Link task
EmailSummary
Email summary task
Note: taskId is only unique within a taskType. Always use both together — taskType=Package&taskId=42 and taskType=Query&taskId=42 refer to different tasks.
Endpoints
Workspaces
Returns all workspaces the authenticated user has Viewer or higher access to.
Response 200 OK
"key": "finance",
"name": "Finance",
"description": "Finance data governance workspace"
"key": "sales",
"name": "Sales",
"description": null
Field
Type
Description
key
string
Unique workspace identifier — use this value in all other endpoints
name
string
Display name
description
string | null
Optional description
Process Maps
GET /api/v0/orchestration/{workspace}/process-maps
Returns process maps in the given workspace.
Pass all as {workspace} to retrieve process maps across every workspace the user can access.
Path parameters
Parameter
Description
workspace
Workspace key from the workspaces endpoint, or all
Query parameters: uat, limit, offset
Response 200 OK
"processMapId": 42,
"name": "Daily Finance Load",
"workspace": "finance",
"lastExecutionDate": "2026-03-14T22:00:00",
"successfulTasks": 18,
"failedTasks": 0,
"runningTasks": 0,
"queuedTasks": 0,
"disabledTasks": 2
Field
Type
Description
processMapId
int
Unique process map ID
name
string
Display name
workspace
string
Workspace key
lastExecutionDate
datetime | null
When the process map last ran (local time)
successfulTasks
int
Number of tasks that finished successfully
failedTasks
int
Number of tasks that failed
runningTasks
int
Number of tasks currently running
queuedTasks
int
Number of tasks waiting to run
disabledTasks
int
Number of disabled tasks
GET /api/v0/orchestration/{workspace}/process-maps/{processMapId}/tasks
Returns all tasks belonging to a specific process map.
Path parameters
Parameter
Description
workspace
Workspace key
processMapId
Process map ID
Response 200 OK — array of task objects.
Error responses
Status
Cause
404 Not Found
Process map does not exist or user has no access
POST /api/v0/orchestration/{workspace}/process-maps/{processMapId}/trigger
Triggers a process map to run. Returns immediately; execution is asynchronous. Requires Contributor access on the workspace.
Path parameters
Parameter
Description
workspace
Workspace key
processMapId
Process map ID
Request body
"uat": "Production"
Field
Type
Description
uat
string
Environment to run against. Defaults to Production if omitted.
Response 202 Accepted — empty body.
Error responses
Status
Cause
403 Forbidden
User does not have Contributor access on the workspace
404 Not Found
409 Conflict
Process map is already running
Tasks
GET /api/v0/orchestration/{workspace}/tasks
Returns all tasks in the workspace, grouped across all process maps.
Pass all as {workspace} to retrieve tasks from every accessible workspace.
Path parameters
Parameter
Description
workspace
Workspace key or all
GET /api/v0/orchestration/{workspace}/tasks/{taskType}/{taskId}
Returns details for a single task.
Path parameters
Parameter
Description
workspace
Workspace key
taskType
Task type — see Task types reference
taskId
Task ID
Response 200 OK — a single task object.
Error responses
Status
Cause
400 Bad Request
taskType is not a recognised value
404 Not Found
Task not found in any accessible process map
POST /api/v0/orchestration/{workspace}/tasks/{taskType}/{taskId}/trigger
Triggers a single task to run. Returns immediately; execution is asynchronous. Requires Contributor access on the workspace.
Path parameters
Parameter
Description
workspace
Workspace key
taskType
Task type — must be a value from Task types reference
taskId
Task ID
Request body
"uat": "Production"
Error responses
Status
Cause
400 Bad Request
403 Forbidden
404 Not Found
409 Conflict
Task is already running or queued
Task object
Used in both the workspace task list and the process-map task list.
"taskId": 1005,
"taskName": "Load Customer Dim",
"taskType": "Package",
"status": "Finished",
"processMapId": 42,
"processMapName": "Daily Finance Load",
"lastExecutionStartTime": "2026-03-14T22:00:05",
"lastExecutionEndTime": "2026-03-14T22:01:32"
Field
Type
Description
taskId
int
Task ID — unique within a task type
taskName
string
Display name
taskType
string
See Task types reference
status
string
Finished, Failed, Running, Queued, Outdated, Disabled
processMapId
int | null
ID of the containing process map. null for tasks not belonging to a specific map.
processMapName
string | null
Name of the containing process map
datetime | null
When the task last started (local time)
datetime | null
When the task last finished (local time). null if currently running.
Executions
These endpoints provide visibility into when tasks ran, how long they took, and what output they produced.
GET /api/v0/orchestration/{workspace}/executions
Returns the latest execution state for every task in the workspace — one entry per task. Use this to build a status dashboard or health check.
Path parameters
Parameter
Description
workspace
Workspace key
Response 200 OK
"taskId": 1005,
"lastStartTime": "2026-03-14T22:00:05",
"lastEndTime": "2026-03-14T22:01:32",
"duration": "01m 27s"
"taskId": 2010,
"taskName": "Validate Customer Count",
"taskType": "Query",
"status": "Failed",
"lastStartTime": "2026-03-14T22:02:00",
"lastEndTime": "2026-03-14T22:02:03",
"duration": "03s"
"taskId": 3001,
"taskName": "Send Summary Email",
"taskType": "EmailSummary",
"status": "Running",
"lastStartTime": "2026-03-15T08:30:00",
"lastEndTime": null,
"duration": ""
Field
Type
Description
taskId
int | null
Task ID
taskName
string
Display name
taskType
string
status
string
lastStartTime
datetime | null
When the last execution started (local time)
lastEndTime
datetime | null
When the last execution ended (local time). null if currently running.
duration
string
Human-readable duration of the last completed run (e.g. 1h 02m 15s). Empty if no completed run yet.
Error responses
Status
Cause
403 Forbidden
User does not have access to the requested workspace
GET /api/v0/orchestration/{workspace}/tasks/{taskType}/{taskId}/executions
Returns the execution history for a specific task, newest first.
Path parameters
Parameter
Description
workspace
Workspace key
taskType
Task type
taskId
Task ID
Query parameters: uat, limit (default 50), offset
Response 200 OK
"executionId": 98231,
"startTime": "2026-03-14T22:00:05",
"endTime": "2026-03-14T22:01:32",
"durationSeconds": 87
"executionId": 97105,
"startTime": "2026-03-13T22:00:07",
"endTime": "2026-03-13T22:00:09",
"status": "Failed",
"durationSeconds": 2
"executionId": 97210,
"startTime": "2026-03-15T08:30:00",
"endTime": null,
"durationSeconds": null
Field
Type
Description
executionId
int
Unique execution ID — use this to retrieve logs
startTime
datetime
When the execution started (local time)
endTime
datetime | null
When it finished (local time). null if still running.
status
string
Finished, Failed, or Running
durationSeconds
int | null
Duration in whole seconds. null if still running.
Error responses
Status
Cause
400 Bad Request
taskType is not a recognised value, or limit/offset out of range
403 Forbidden
User does not have access to the workspace
404 Not Found
GET /api/v0/orchestration/{workspace}/tasks/{taskType}/{taskId}/executions/{execId}/log
Returns the log output recorded during a specific execution.
Log entries contain the output and error messages written by the execution engine during the run. For Query and CompareQuery task types, logs are not stored in this format and an empty array is always returned.
Path parameters
Parameter
Description
workspace
Workspace key
taskType
Task type
taskId
Task ID
execId
Execution ID — from the /executions list
Response 200 OK
"logTime": "2026-03-13T22:00:07",
"log": "Starting package execution: Load Customer Dim"
"logTime": "2026-03-13T22:00:08",
"log": "Connecting to source: dw-prod.database.windows.net"
"logTime": "2026-03-13T22:00:09",
"log": "ERROR: Connection timeout after 30s. The remote server did not respond."
Field
Type
Description
logTime
datetime
When this log entry was written
log
string
Log message (may include error details, stack traces, or informational output)
Returns [] (empty array) for Query and CompareQuery task types.
Error responses
Status
Cause
400 Bad Request
403 Forbidden
Error reference
All error responses return JSON in the following format:
"type": "https://tools.ietf.org/html/rfc9110#section-15.5.5",
"title": "Not Found",
"status": 404,
"traceId": "00-abc123def456..."
400 Bad Request responses for an unrecognised taskType return a plain-text message listing the valid values:
Unknown taskType 'Pkg'. Valid values: Query, CompareQuery, Package, ObjectGroup,
Process, ScheduleGroup, TestGroup, OrchestrationMap, Link, EmailSummary, Rule.
Status code summary
Code
Meaning
200 OK
Request succeeded
202 Accepted
Trigger accepted — execution started asynchronously
400 Bad Request
Invalid parameter value (see response body)
401 Unauthorized
Missing or invalid API key
403 Forbidden
API key is valid but lacks sufficient access to the requested resource
404 Not Found
Resource does not exist or is not visible to the authenticated user
409 Conflict
Trigger rejected — process map or task is already running
Interactive API explorer
A Swagger UI is available where you can browse all endpoints and test them directly in the browser:
https://{tenant}.odq.timextender.com/swagger          (production)
  1. Open the Swagger UI.
  2. Click Authorize (top right).
  3. Enter your API key in the X-API-Key field.
  4. Click Authorize, then Close.
  5. Expand any endpoint and click Try it out.
Discover available workspaces
curl https://acme.odq.timextender.com/api/v0/orchestration/workspaces \
-H "X-API-Key: txk_your_key_here"
List all tasks in a workspace
curl "https://acme.odq.timextender.com/api/v0/orchestration/finance/tasks?limit=50" \
Get the current status of every task (dashboard)
curl "https://acme.odq.timextender.com/api/v0/orchestration/finance/executions" \
Find failed executions for a task
curl "https://acme.odq.timextender.com/api/v0/orchestration/finance/tasks/Package/1005/executions?limit=10" \
Read the log for a specific failed run
curl "https://acme.odq.timextender.com/api/v0/orchestration/finance/tasks/Package/1005/executions/97105/log" \
Trigger a task
curl -X POST "https://acme.odq.timextender.com/api/v0/orchestration/finance/tasks/Package/1005/trigger" \
-H "X-API-Key: txk_your_key_here" \
-H "Content-Type: application/json" \
-d '{"uat": "Production"}'
Trigger an entire process map
curl -X POST "https://acme.odq.timextender.com/api/v0/orchestration/finance/process-maps/42/trigger" \
Page through a large task list
# Fetch in batches of 25
curl "https://acme.odq.timextender.com/api/v0/orchestration/finance/tasks?limit=25&offset=0" -H "X-API-Key: txk_your_key_here"
curl "https://acme.odq.timextender.com/api/v0/orchestration/finance/tasks?limit=25&offset=25" -H "X-API-Key: txk_your_key_here"
curl "https://acme.odq.timextender.com/api/v0/orchestration/finance/tasks?limit=25&offset=50" -H "X-API-Key: txk_your_key_here"
