Upgrading TimeXtender Orchestration and Data Quality
In this article, you are going to read about upgrading TimeXtender Orchestration and Data Quality hosted on-prem.
Things to know before you begin
  • TimeXtender Orchestration and Data Quality can be installed on multiple servers, make sure to have access to them all before you begin. You can find the servers that need to be upgraded under General > Execution Connections inside TimeXtender Orchestration and Data Quality.
  • Before we begin upgrading it is highly recommended to take a backup of the Database. This can in some cases takes a while.
  • You cannot upgrade while an TimeXtender Orchestration and Data Quality execution is running so it is recommended to upgrade outside execution hours. Common execution hours are 7-9, 11-13, 15-17, and 22-5.
  • TimeXtender Orchestration and Data Quality 5.3 started to require .NET Framework 4.8 and that install might require a restart on that particular server. If your server is missing .NET 4.8 the TimeXtender Orchestration and Data Quality setup will link to the appropriate Microsoft installer.
Upgrading is relatively simple, our TimeXtender Orchestration and Data Quality upgrading tool should guide you through most of it.
These are the steps you need to take:
  1. Download an TimeXtender Orchestration and Data Quality upgrade file.
  2. Execute the TimeXtender Orchestration and Data Quality upgrade file on the main TimeXtender Orchestration and Data Quality server, the one that handles the schedule
  3. IMPORTANT: Do not start upgrading other execution connections while the schedule server is being upgraded. Afterwards, multiple execution connections can be upgraded simultaneously.
  4. If you are unsure which server is your schedule server you can find out in the Windows Task scheduler
  5. The schedule server will have this windows schedule enabled
  6. The TimeXtender Orchestration and Data Quality upgrader will then guide you through the upgrading process
  7. Do the same thing on the other execution connections
Error: TimeXtender Orchestration and Data Quality is already running
The most common annoyance in the upgrading process is execution is already running.
When you see this error, it is important to understand what this means.
In this case, we can see from the Product column that TimeXtender Orchestration and Data Quality Administrator is running so in those cases it is recommended to talk to the user running TimeXtender Orchestration and Data Quality Administrator and ask if you can kill it. Most of the time the user will have already saved his or her work and killing it will be a none issue.
You can also have TimeXtender Orchestration and Data Quality epcmd running which requires a bit more thought and knowledge of your company's processes, whether you can safely stop execution or if you need to wait until it finishes. If you are unsure, we recommend rather waiting until it finishes.
Tips and tricks
One trick to prevent the scheduler from executing new TimeXtender Orchestration and Data Quality epcmd instances is to disable the windows scheduler on the schedule server.
If you do this, it is very important to remember to start it up again, TimeXtender Orchestration and Data Quality will not execute again until you do so.
For added safety, it’s also advised to select Run after enabling the task schedule.
If you expect users to execute from the portal, another good trick is to open the server hosting the Portal and disable the Command service. This will prevent users from manually starting executions until TimeXtender Orchestration and Data Quality has finished upgrading on the server.
bas.hopstaken
  • 91 replies
  • July 30, 2024
Hi @Christian Hauggaard ,
Where can we download a Exmon Upgrade file?
  • July 30, 2024
for Exmon DG / Orchestration you need to request an upgrade I think.
@bas.hopstaken  the upgrade file (i.e. latest version of the software) can be downloaded here:
