Stop/ kill a running execution within Exmon DG
devin.tiemens
Does anyone knows if it is possible to stop/ kill a running execution within Exmon DG?
Best answer by Trine Stuhr
Hey Devin,
if you go to “Process Que” in the webportal you should be able to stop any running executions:
I’m not fully sure if you are able to do it within the DG desktop
Trine Stuhr
  • 15 replies
  • July 25, 2024
Hey Devin,
devin.tiemens
  • 90 replies
  • July 25, 2024
Ah oke thanks, didn't know this either.
