When you open a project, the default version is always the latest saved version of the project. To open a previous version of a project, follow the steps below:
  1. Click on File > Open. Or, use the shortcut key CTRL+O.
  2. (optional) If you have multiple projects, select a project in the project drop-down list.
  3. To select a previous project version, click Select Version. This will show a list of previous versions of the project as shown below.
  4. Select a version and click OK. This will return you to the project open dialog, with the selected version shown.
  5. Click OK to open this version of the project.
Best Practices
  • Periodically backup your TimeXtender Repository database which contains all your projects and their versions.
  • Write a descriptive Version note for project versions, especially after reaching major milestones in design. This may help restore or revert-back to a working configuration when needed.
