Why is my TimeXtender Classic repository database so large, and how to clean up?
  • February 24, 2025
  • 26 views
A variety of factors can contribute to the growth of your TimeXtender repository database.  Depending on the cause, there are a number of remedies that you can apply.
Execution Package Logs
TimeXtender records details of every execution.  These logs can begin to take up a lot of disk space, especially if your projects have execution packages that run more than once per day.  Removing older logs can help reduce the repository's size, although you will not be able to restore those later.
To remove these logs, open the Tools menu, select Repository Administration, and click on the Execution Package Logs tab:
From here, you can view the logs for all of the projects in your repository.  By picking a start date, a stop date, and a project, you can control which execution packages appear in the list.  You can then select and delete older logs that are no longer useful.
To select a section of rows in the window, start by highlighting a row, then go to the end of the section and mark while pressing Shift + Left click.  You may also select all rows with Ctrl + A key.
SSIS Logging
Very large repository size and rapid repository growth is often due to SSIS logging.  To see if SSIS logging is enabled, edit your project and look to see if the Enable SSIS logging box is checked:
SSIS logging creates extremely detailed logs of the SSIS transfer process which can be useful in some advanced troubleshooting situations.  However, we strongly recommend that you disable this option unless there is a pressing need to turn it on.  The reason for this is that executing a single table only once can add hundreds or thousands of rows in the project repository database.
If this option is turned on in your project, SSIS logs probably constitute a majority of your project repository's memory footprint on your hard disk, and we recommend turning it off.  After you uncheck this option, you will need to re-deploy any table in your project that uses SSIS for data transfer in order to fully commit the change.
SSIS log records are stored in the table "sysssislog" in your project repository database.  This is a database system table that will not show up in your project or in the repository database's list of regular tables when viewed in SQL Server Management Studio.  Unless you have a specific reason to keep these logs, it should be safe to remove them as they are not used in the TimeXtender.
In order to remove all logs in this table, open up SSMS and run the following query against your project repository.
TRUNCATE TABLE dbo.sysssislog
a script to remove all rows not containing error messages:
delete from dbo.sysssislog where event <> 'OnError'
Repository Age
The project repository contains a record of every version of every project you have ever created.  Over the years, this can eventually cause the repository database to grow.  However, it's not always necessary to keep very old versions of the project easily accessible and archiving these records can save disk space.
To archive your old repository, export all of your current projects and make a backup of your repository database.  Then, drop your repository database and re-create a new version of the repository through the TimeXtender UI.  Finally, import your projects into the new repository.
Note that if you are using multiple environments, you will need to reconfigure your environment settings in your new repository.
While the new repository takes up much less space on the disk, and certain functions may run faster, accessing older versions of your project will become more challenging after archiving the old repository.  To restore to an earlier version, you would need to restore the archived database under a new name, open the version you want, export the project, and import it into your new repository.  However, if restoring older versions is usually relatively uncommon, this trade off may be worth considering.
