Create a column in table using If Function
  • May 15, 2023
  • 339 views
Acumen
Visitor
I’m very new to TimeXtender and was hoping someone could assist with my issues.
How would you use an “If” function in TimeXtender?
For example, I need to create a new column in my table called “Quantity” . I then need to look at the [code] column in the same table and bring back a value using an If Function.
Something like this:
If [code] = 1 then ‘small’ else if [code] = 2 then ‘medium’ else if [code] = 3 then ‘large else if [code] = 4 then ‘x large’ else null.
Thank you
Hi Claire
Here is how I would do something like that in TimeXtender.
I would create three fixed values on the field and then add conditions to these fields.
It goes through the options in alphabetical order, so I do not need to add a condition to the last one. If the first two conditions do not apply it will just add this one. If I wanted to be sure it only got set if it had a value I would add a condition to this as well. Then if any given Type was different from the set options it would not be set with a value.
Here is how the transformation view looks if I set a condition on all three options.
As you can see the code generated is similar to what you would normally do for a IF statement in SQL.
  • 1091 replies
  • May 15, 2023
Hi Claire
