Date difference
I have a table with dates of employees when they start and end work each day. Some days the start of work day is not the same as the end of the work day. Example : employee 2 start work 07-08-2023 end work 09-08-2023. This means that the employee is sick in the period. I have a condition that set this employees work time to 7.5 hours. I have to split up the dates where start_date <> end_date. So that i in the interval can add 7.5 hours to the employee each day he was sick. How can i do this?
This is a screenshot where the dates are different. Sorry about the launge “mekaniker” is the employee and “Antaltimer_Frokost” means being sick
The end result i want is to get 7.5 for each day, so at the first i would like 7.5 + 7.5 . So for the last employee “95012” i want 7.5+7.5+7.5. Hope its clear what i want
Hi @Kristoffer
You would need to make it have more rows than exists.
Look at this guide for reference.
https://legacysupport.timextender.com/hc/en-us/articles/115005972746-Improve-execution-times-by-splitting-exchange-rates-out-on-dates#the-exchange-rate-table-contains-both-start-and-stop-date
In essence you need to use the date table to add more dates than is existing and then fill out the dates with 7,5 hours if necessary.
  • 1091 replies
  • August 14, 2023
Hi @Kristoffer
  • 1091 replies
  • August 14, 2023
Also this seems really similar to the other question. In any case the solution is the same as were suggested in that.
