Multiple environment transfer after upgrade of servers
  • January 21, 2025
  • 4 replies
  • 49 views
Hello,
I have an Acceptance and Production environment and using multiple environments transfer.
Now both servers are new and also TX is upgraded (latest version) and the connection between them seems to be gone after this. How do I setup the multiple environment again ? Just by adding an environment or can I get it back from the ‘old’ TimeXtender ?
Thanks,
Ronny
Hi ​@rluyten
I have made a video.
https://use.vg/5TAJZ3
As you can see it is possible to remove and add environments as long as the old setup exists and the service is running.
If you remove test in a dev - test - prod setup you will experience that test will be third in the sequence, so I removed production as well. Also to show how it really takes no time to do.
  • 1095 replies
  • January 23, 2025
Hi ​@rluyten
@rluyten Did the comment above answer your question? If so please help us by marking a best answer above. Please let us know if you have any follow up questions
  • 11 replies
  • February 18, 2025
Sorry for the late reply but some changes need to happen to the servers before I can setup the multiple environment. But video looks very good so I am sure I will manage.
Thanks,
Ronny
  • 11 replies
  • February 26, 2025
Just finished, at the end I just needed to change the server ID.
So all good, thanks.
