Which sql server is supported for timextender 20.10.20.64
Hello,
We would like to update our sql server if this is possible. We use TimeXtender version 20.10.20.64. Untill which version of SQL server does TimeXtender support?
Hi @Roy VH 20.10.20 supports SQL Server 2019. Support for SQL Server 2022 was added in 20.10.41
  • 4 replies
  • October 3, 2023
Thanks for your answer
