Question
Issue with relationships .. in a many-to-many-scenario
  • October 28, 2025
  • 5 replies
  • 64 views
Hi there
I have an issue which I’m not quite sure how I can solve in timextender.
i have 2 tables, Vendor and Catalouge .. Vendor contains all the vendors and Catalouge is the productcataloge with information about the product.
The only parameter I have that I can make the relationship on is VAT .. the problem is that many products have the same VAT and there is a multiple Vendors with the same VAT.
I was looking into making a bridge table but Im not quite sure how I can do this automatically in Timextender.
what’s the smartest solution to this?
  • October 28, 2025
this could be the structure of the tables.
  • October 28, 2025
I am not sure what result your are looking for, but it sound like you could try to create a custom view where you join the two tables on vendor.vat = catalouge.vat
This would give you a view where you could probably build a 1-N relationship for both vendors and products
  • October 28, 2025
This is not an answer to your question but please fix the name of the Catalouge table (it should be Catalogue I guess). It's a royal pain in the behind to do it at a later stage when you've got several tabular models and 42 Power BI Reports using the incorrect name :)
  • October 28, 2025
that will be done :-D
  • October 28, 2025
how to approach this depends on what is needed. I would expect a product to have a VAT code of some sort as VAT depends on the product or type of service. There isn't really any logic behind allocating a VAT code to a vendor in my opinion. I expect the allocation of a VAT code to a vendor to be an emergent data point and not truly “real”.
You could create a view/table of all vendors linked to a code, or all codes linked to a vendor, or both, but the question is what you need and whether it makes sense to use this data to create that.
