TimeXtender ver 6675.2
  • 12 replies
What happened to version 6675.2 of TX?
regards,
Bjørn A.
Hi @bjorn
Please run the TX execution server configuration tool and select your instances, then restart the TimeXtender desktop application. This needs to be done after each upgrade as described in the below article:
We will be publishing the release notes for the minor version 6675.2 shortly
Hi @bjorn
Can you please elaborate? Are you encountering an issue?
  • 12 replies
  • July 11, 2024
Hi Christian,
I have installed 6675.2
All of my jobs in TX desktop are invalid (see att.). ODX server works fine.
So i checked out the product update page and I didnt find anything about the 6675.2 version
Do you have any suggestion why my jobs are invalid.
All my previous updates have worked fine :-)
best regards,
Bjørn A.
Hi @bjorn
https://support.timextender.com/upgrades-migration-130/upgrade-timextender-1568?tid=1568&fid=130
