Answer
ODX Rollup task does nothing
I have set up a Storage Management Task with only the Rollup option ticked, and filled in the right ADF credentials. One of my source tables has been selected for this task.
TX says the runs are successful and they finish in a fraction of a second, but nothing happens in the storage account. The version folders contain the full load file + all the incremental files, as before. I have tried with many different settings for min and max rollup file size. I have not specified “folder (optional)”. I have tried with and without specifying integration runtime.
No pipeline run seems to show up in ADF after triggering the task.
This roll up issue appears to be due to Updates & Deletes being enabled in incremental load settings. The product team will look into supporting roll up in combination with updates and deletes in the next build cycle
  • 1172 replies
  • March 18, 2024
Hi @sigsol
You are on the newest version of the ODX as well?
  • 26 replies
  • March 18, 2024
Hi Thomas!
The ODX version is 6521.1.
  • 26 replies
  • March 19, 2024
Hi @Thomas Lind
We have now upgraded to ODX version 6563.1, but there is no change unfortunately. The task runs successfully but nothing happens with the incremental files.
There are no task details in the execution log panel and I can’t see any corresponding pipeline runs in ADF.
  • 1172 replies
  • March 19, 2024
Hi @sigsol
You are using the same ADF setup to do transfers between ODX and DWH, right?
Also about the min max size, the files in the data lake container folders have files larger than the min size? I would guess this is the trigger that is used to merge them. Whether it is across the ones existing or just that one needs to be larger I am not sure.
  • 26 replies
  • March 20, 2024
Hi @Thomas Lind
Correct, we are using the same setup for ODX-DWH transfers.
I have tried having min max sizes larger than both full load and incremental files, smaller than both, and a small min and large max. Is it possible to get a confirmation as to what exactly these limits refer to? I didn’t manage to find an explanation in the documentation.
  • 1172 replies
  • March 21, 2024
Hi @sigsol
You do need a lot of data in your folder to make this work.
1MB is equal to 9765625 kiB (kibibyte)
So the total needs to be larger than that for it to do the roll-up.
  • 26 replies
  • March 21, 2024
Hi @Thomas Lind
All our folders have more than 1 MB. So it should work then?
The number of files in the folder greatly affects performance and we can’t keep doing full loads for some of the sources.
  • 1172 replies
  • March 22, 2024
Hi @sigsol
Can you show how one of the folders look with these batch files? I could not myself generate enough data to make it work and I would like to show if it works or not and with this I can pass it on.
You can try to send it to me on a private message if you think it can’t be shared.
Here is how it looks for me.
