Cdata Evernote
  • November 2, 2021
  • 16 views
Has anyone experience which fieldsto fill to get the CDATA evernote connector working ?
Hi Roland
No there are so many to choose from, but many are similar.
According to this https://cdn.cdata.com/help/SEG/ado/pg_oauthcustomappcreate.htm you need to create an key in the link https://dev.evernote.com/key.php
Other than that it is like all other CData providers that use OAuth authentication. https://support.timextender.com/hc/en-us/articles/360020235918-Authenticate-using-OAuth-2-0
Also explained here: https://cdn.cdata.com/help/SEG/ado/pg_oauthcustomapp.htm
  • 1095 replies
  • November 2, 2021
Hi Roland
