Cdata Sharepoint connection Data Model feature
  • October 14, 2024
  • 40 views
avanrijn
Dear Sir,
I am connecting through Cdata to Sharepoint Online.
I have hierarchies in my Sharepoint data, I can see them when I connect with PowerBI to my Sharepoint site. Can I use the Data Model feature ‘Flatten Documents’ like you can with JSon connectivity ?
It looks like CData for Sharepoint Online doesn't have this capability. Can I somehow bring these ‘hidden fields’ into my TimeXtender  project ?
In the attachment (Knipsel.PNG) you can see the hierarchical option in PowerBI with PowerQuery. I miss these fields when I connect with TX Cdata to the same Sharepoint site.
Hope you can shine a light on this.
Thank you in advance for looking into this case.
Regards,
Arthur
Best answer by avanrijn
Hi Thomas,
Problem is solved.
I found the lookup tables in the Sharepoint Site.
Thanx.
Regards,
Arthur
  • 1094 replies
  • October 14, 2024
Hi @avanrijn
What sort of settings do you use?
There are many fields that give back more info than others.
avanrijn
  • 36 replies
  • October 15, 2024
Hi Thomas,
Problem is solved.
Thanx.
Regards,
Arthur
