Connecting to PostgreSQL database with ODBC
  • November 19, 2024
  • 56 views
avanrijn
Dear Sir,
I want to connect to a PostgreSQL database via ODBC.
So I found these posts how to fix this.
But I am using TX version 6766.1.
Can someone please point me the way how to fix this with the latest and the greatest version of TimeXtender.
See Word document in the attachment with my setup.
https://legacysupport.timextender.com/hc/en-us/articles/4410466782621-Create-a-ODBC-data-source-in-a-ODX-or-with-a-Any-Source-ADO-Net-provider-in-a-Business-Unit
Thanxs in advance.
Regards,
Arthur
Hi ​@avanrijn Can you please try to use the ODBC provider and then enter the DSN name that has been specified in ODBC Administrator
Then you can edit the data source in TimeXtender Data Integration and click advanced settings to change schema properties
avanrijn
  • 36 replies
  • November 20, 2024
Hi Christian,
Yes, it worked !
Thank you very much.
Regards,
Arthur
