DB2 connector querying the wrong schema when selecting tables
  • February 16, 2023
  • 8 replies
  • 144 views
anders.e.jonsson
We have set up a db2 connector in an installation with the new version of Timextender. The connection is ok.When we make a search to select tables, nothing turns up. Both the schema and table filters are set to <All>.
It seems that Timextender searches the schema [sys_tables], but the server uses the schema [systables]. Without the underscore.The schema [sys_tables] exists on the server, but contains no data. I created a Query Table (Select * from [sys_tables]). It was executed succesfully in a Transfer task, but only returned empty columns.
Is it possible to change the script so that the query uses the schema systables?
I couldn't find anything about it in CData's online manual
The Timextender version is 6143.1, and the CData DB2 version is 22.0.8389.9
Hi Anders
Just an update to this, as we have a Zendesk ticket regarding this.
It was possible to use a default ODBC data source that used a DB2 provider set up on the server.
It has some additions that would make it work better, but it does work as a method to gain access to a DB2 data source in the new version of TimeXtender (i.e. v 6xxx).
  • 233 replies
  • February 16, 2023
In my experience, I’m using a Linked server with OLE DB connector (Client Access) to connect to our AS/400 (iSeries v5r4) several years ago, and now, with TX this setup works perfectly using the SQL TimeXtender connector.
anders.e.jonsson
Thanks rvgfox. We will try that.
  • 1147 replies
  • February 16, 2023
Hi Anders
Alternatively I can ask CData to explain what can be done when a setup is for Sys_Tables instead of SysTables.
I would need a log for what happens when you synchronize to possibly make it show that it do not contain.
anders.e.jonsson
Hi Thomas,
Thanks! We’ will try linked server first. If that doesn’t work I’ll get back with log files.
anders.e.jonsson
Hi  @Thomas Lind ,
I have attached a log file.
The DB2 version is 9,7, and is installed on a Windows server.
When the customer tested Timextender V20 last autumn, the DB2 connector included worked fine. Unfortunately it’s uninstalled, so I don’t know which version of CData’s connector it was.
  • 1147 replies
  • February 23, 2023
Hi Anders
I have asked CData.
  • 1147 replies
  • March 2, 2023
Hi Anders
Just an update regarding the current progress of this issue.
Hi Thomas,
I sent this to our development team for further review. I will keep you posted as soon as I have an update.
Regards,
Quinn Freas
  • 1147 replies
  • March 30, 2023
Hi Anders
