Delete data due to privacy legislation
  • October 15, 2019
  • 16 views
We want to delete the data in TimeXtender after a period of 5 years because of the GDPR legislation . Is there a possibility to get this handled by TimeXtender?
Best answer by JTreadwell
Hi Rob,
There are many ways to handle this in TimeXtender such as configuring data selection rules.
However, since GDPR regulation applies to all data, not just the data warehouse and analytics, we recommend the data be deleted in the source applications. These deletions in the source will also remove the data in TimeXtender as long as you have hard deletes enabled when utilizing Incremental load.
Hope this helps.
JTreadwell
Hi Rob,
Hope this helps.
