Duplicate tables in ODX Storage
  • April 27, 2023
  • 81 views
I am working on Sandbox Environment.
I on using ODX 20.10.36.64.
I executed tables on 25th and today 27th in ODX DataSource.
What I noticed is in my SQL server new tables were created.
Do I need to update any settings to resolve this?
SQL server
Hi Sowjanya
If you add a management task as explained in the following guide
You can clean up the ODX store so only one version persists.
  • April 28, 2023
Hi Sowjanya
  • May 2, 2023
Yes, it worked. I am using the version to keep ‘2’
