if i start timextender the first thing doen is “loading odx project information” this hangs.
my version is 20.10.46.64
already restarted whole server , didn’t make any difference
Best answer by Bernarddb
We have been investigating the problem. We arn't using the ADF transfer from ODX → MDW but the ado.net transfer. And we run the ODX server on the same machine as we run the TX client. It seems that our Disk space was full and after cleaning up, the odx started working again and we can execute again. We still have some problems with a few tables that we are investigating, but 80% looks te be working currently.
Enter your E-mail address. We'll send you an e-mail with instructions to reset your password.
